Hydraulic remote help
Posted: Thu Apr 03, 2014 8:40 pm
by Beauwh
I wanting to add a hydraulic outlet to my super dexta so I can use a haybine that has a single acting hydraulic cylinder. This is what Im working with. Im just not sure what needs to be done to make this work. Can someone point me in the right direction? Thanks
Re: Hydraulic remote help
Posted: Thu Apr 03, 2014 11:12 pm
by dexta roadless
It's quite easy. Take out theplug you have marked "1" and screw in a 1/2" pipe connection of some sort. when you use it, pull out the knob you have marked 2 activate the external service and use it by operating the main handle.
Posted: Fri Apr 04, 2014 12:57 am
by Beauwh
So for a single acting hydraulic cylinder thats all I need to do? I dont need a return line?
Posted: Fri Apr 04, 2014 12:06 pm
by peter2
another question, because the picture shows it very good: How is the valve (Nr. 2 in the photo above) dismantled, which switches between 3pt linkage and the external pipe? It looks similar to that on my super major, but mine does not move.
Can I turn the big round cover?
Peter
Posted: Fri Apr 04, 2014 6:37 pm
by Jerry Coles
for earlier Hydraulics these pics might help:
http://s1106.photobucket.com/user/oldtr ... t=3&page=1.
Posted: Sun Apr 06, 2014 12:32 am
by Beauwh
To my surprise the the aux knob works good. I expected it to be froze being that the knob is missing. I just put a washer and nut on the threads to make it easier to pull. Can anyone tell me how to check the hydraulic fluid level?
Posted: Sun Apr 06, 2014 8:04 am
by Bensdexta
Posted: Sun Apr 06, 2014 8:10 am
by Bensdexta
Posted: Mon Jun 23, 2014 7:35 am
by dexta64
Posted: Mon Jun 23, 2014 9:30 am
by dexta64
Posted: Wed Dec 08, 2021 12:58 am
by EddieJ
My web site hosting has changed, its no longer with moonfruit but you can find the same information here:
https://www.fordsonsuperdexta.co.uk/Hydraulics
Currently updating all my links on FTP Forum
