towing socket
sky blue
towing socket
Post by sky blue »
hi . i need to put a scoket for towing a trailer on my dexta, ihave nothing
wired up on the tractor only the starter /alternator. and a set of indicators.
this is all the basic that i needed , now iam wanting to put in the towing socket.
to plug in the trailer , is there a simple way for a simple person [me] :D to do this
connecting from battery to trailer socket,
Re: towing socket
Post by Bensdexta »
Clearly you will need to devise a bracket on which to mount your trailer socket. Then just google on the wiring diagram for your chosen socket (typically a 7-pin '12N' socket in UK) and decide which lights you have and wish to wire to your trailer - eg you may not have a brake light on your tractor, so clearly you can't wire this up. Perhaps in your case it will just be runnning night lights + L/R indicators. Then just take a parallel feed from each of your chosen lighting circuits to the corresponding pin on your trailer socket. Don't forget the earth!
sky blue
Re: towing socket
Post by sky blue »
thanks bensdexta, thats the information i was needing have just got the socket mounted ,
now to sort the wires ill get the indictors wired up for now and
get the back lights ect again :) , sky blue
Re: towing socket
Post by Jerry Coles »
Hi Sky Blue
If you look at the top of the dexta pages you'll see an entry called "Wiki shortcut, home page link and torque settings". Go into this and as you scroll down you will see an article I wrote about modernising you Dexta's electrics. This may be of use to you.
sky blue
Re: towing socket
Post by sky blue »
hi gerry, had seen your wiring digrams,good stuff and you have put abit
of time into it , but as usual my wiring is all bits and bobs as you do.
try to make do with what yo have and never seem to get it perfact, :eyes:
the towing socket i bought was a 7 wire which was to many for all that i need
the board type ihave with lights ect is a seven wire with
just 5 beening used an was wired slightly different ,
so iam in the process of trying to get this sorted , this is not as easy as i thought,
but ithink ihave got it sussed now , time will tell , i think ill keep the fire department number handy :lol:
niallsdexta
Re: towing socket
Post by niallsdexta »
Hi Sky Blue,
this is a easy enough task, where are you based in Ireland, if you send me a PM, maybe we are base close and i can give you a dig out if required :thumbs: .
I don’t know what I am doing!
sky blue
Re: towing socket
Post by sky blue »
woopee, ihave trailer lights an indictors :clap: any one needing electrics sorting,
give me a ring on second thoughts :scratchhead: better not this was my usual hit and miss luck
jobs, but thanks for all the input lads , neilsdexta im in dear ol donegal but as you can see im now an
expert on all things electric might even try for ajob as an auto spark :D
niallsdexta
Re: towing socket
its great when another job's done, always a good feeling
