64 will not start.
Posted: Mon Dec 08, 2014 3:23 pm
Good day all. I have an issue. I did an oil change on my 64 this weekend and while doing so I pulled the glow plug and found it to be bad also I check the induction sprayer and it works good. The problem is after doing the listed things above I started it up and let it run, I did not remember that I closed the fuel shut off on the left side of the tank and it died due to lack of fuel. I opened the shut off and tried to restart but it refused. Do you think I need to bleed the system?
Thank you,
James
Thank you,
James
