As some of you know, I have just totally re-built mine, meaning three liners, one conrod, pistons, rings, crank re-grind, new shells, new oil pump, basicly everything is brand new and tight.
I have put 15w 40 oil in it, should it be different or is that ok to run it on for a bit?
I bought a little gauge which goes up to 60psi which I screwed into the block, I havent started the engine yet, but even turning it over on the starter its showing 60psi!!!
Is something not right here, or am I just worrying a bit too much?
