What I want to know is, to remove the tacho drive do you just undo the four bolts? Just thought I would check before I attempt it
I've not removed the end of my pump, so can't advise on this other than to say I think disassembly is covered in the workshop manual.Nick wrote:I just really wanted to make sure that if I take the end of the pump off where the tacho cable screws in, that I wouldn't damage anything![]()
I couldnt see the three photos at the end of that link, have they expired?
