Identify This Fordson
RChambliss
Post by RChambliss »
This was my father's Tractor, I do not have any information on it and I've searched for serial numbers on the tractor. I will get some numbers off of it to put on the forum. Take a look at the photos and see what you think. I am also looking to sell it as well, any ideas of what it's worth?
http://rs1377.pbsrc.com/albums/ah65/rch ... 1423019318
RChambliss
Re: Identify This Fordson
Fordson Major Diesel between 1954 and 1957 I would suspect.
county654
Post by county654 »
.......with incorrect colour on the rims. The Fordsons out of that time had a blue/orange combination.
Regards Matthias
With County, you can ;-)
1959 Power Major
1963 Super Major
1964 NP Super Major 4x4
1966 County 654
Hmm,
I think its a Power Major without a dash fitted. Flat tank and long steering column makes me think that.
rgds
Looks like it has an upright pump and no breather on the timing cover Emiel
Hello Brian,
You're right I think. On photobucket you can enlarge the picture. The pump is upright and the throttle control runs through the block and not around the block as on MKII engines.
On the nearside we also see the hole for the radiator shutter handle in the tank support. And a customized exhaust pipe. :lol:
The fuel tank and steering column are changed sometimes it seems.
Rgds
anthonygos
Post by anthonygos »
Fordson Major Diesel, need more clear photo's to be sure.
ford5000y
Post by ford5000y »
This is quite tricky; the tractor has 38" rear rims but they are of different designs.
I f you're going to look closely at the 1st picture, the rim has the sort of "extra step" into it, while the 2nd picture which shows the other side the other rim had a different design. My question is: which one is correct, the "stepped" one on the 1st pic , the "non-stepped" one on the 2nd pic, or both were used by fordson? :scratchhead:
