Rebuilt dexta will not start.
I have just had a full rebuild done on the 62 dexta.. It will not come to life at all,, it is also getting a lot off pressure coming back through the air cleaner, when being cranked over. I have checked my valve clearance over and over done them too .012.. Just the pops off pressure through the air cleaner is worrying me. Thanks
Re: Rebuilt dexta will not start.
Are you sure the timing is correct... crankshaft, valves & fuel pump? See workshop manual.
Yeah I'll take the covers off and have a look.. It's just a engineering place, did the rebuild I was hoping they got the timing set right..
