sorry its me again
on my dexta i have a new hand throttle lever but the rod (part No 957E-9807) that it connects to is broken and i have a mole grip as a throttle handle, can any one help were i can get one from in the uk.
its the rod that goes through the dash down the side of the fuel tank and connect to the throttle linkage that attaches to the cam on the side of the air filter
thank you
throttle control lever
Re: throttle control lever
Try Bertie Dunlop or Malcomn Hipperson.
got on from old20 tractor parts £20 inc delivery UK,
2 types one with woodruff key and slight crank (later) and one with hole and straight (early)
mine was the early one with the hole so i am making a key from a rod and bar so the hand throttle will grip and not slip round.
The ones with the hole just take an imperial size roll pin.
thank you will see what i have knocking about
Do you know what size of roll pin to attach the throttle lever?
I took mine to a local John Deere distributor and they pulled out a box of assorted roll pins and found the right size.
Mike
Mike
1959 Dexta
Thanks Mike
