Hi all
Just a quick question regarding livedrive dextas...
What is needed to convert non-live-drive to livedrive?
Dexta livedrive conversion
Re: Dexta livedrive conversion
Everything from the flywheel backwards to the rear axle except the housings. Not really an economic proposition unless you have a donor tractor.
The simple, quick answer.......just buy a second Dexta with livedrive
Fordson PETROL Dexta
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
Fordson Super Dexta
Ford 3000
Ford 4000
Valtra/Valmet 900
I'm wrong in thinking it's just the gearbox then..? Thanks all
Yes, you need a new flywheel adapter, clutch, clutch thrust bearing and hub and clutch linkage for a start
hi.there is an overrun pto adapter that fits on the pto
to stop overrun over tractor when useing an implement
can be bought in most tractor shops might be an easeir
way to go
way to go
