up date on oil pressure
Posted: Mon Jun 08, 2015 10:08 am
by spike
fitted T adapter in block, put the new sender in and a pro oil pressure gage.
(still have no thermostat in yet) started on 1st flick over from cold (just start up smoke) pressure hit 60 psi and sat there
put the topper on and set off cutting, soon got to 150 temp in the blue oil pressure still just under 60 psi after 15 mins it dropped slowly to 50 psi and the over the next 30 mins dropped to 25/30 psi and the oil light came on (agriline say the sender it set to come on around 25/30 psi), temp still 150 in blue,
so i set of it some thick stuff and dropped the cut hight to make it work harder and had to got back wards to cut some of it, temp did got up to just before the red when in reverse but soon back in blue when going forwards, oil pressure now down to about 15 psi (just under 1 bar) and it stayed there even on tick over when dropping off topper.
what is the lowest working (pto revs) pressure that will not course any damage please, if it runs at 15/20 psi and oil is getting to rockers and not over heating i think i may leave any drastic work to the winter months.
any advice always welcome
Re: up date on oil pressure
Posted: Mon Jun 08, 2015 3:48 pm
by Bensdexta
Is that with W30 grade oil?
Posted: Mon Jun 08, 2015 7:25 pm
by spike
yes W30 oil
have got some 20w50 ready to replace it
Posted: Mon Jun 08, 2015 8:34 pm
by jambug123
I would give the engine a good service and use 20/50 engine oil and replace the sender with one from a CNH dealer.
In my opinion with parts cheaper isn't always better as you usually end up buying twise I'm not a fan of using cheap parts when it comes to engines,breaks and bearings.
15psi at idle is good with a hot engine and single weight oil the light shouldn't be on at that pressure it should be on much lower at 7-9psi
at normal operating speed the engine oil pressure should be around 40psi
James
Posted: Tue Jun 09, 2015 9:40 am
by spike
Hi james
thank you for the info.
I have changed oil +filter, fuel filter,air filter, put a fan cowl on the rad, flushed the coolant out and replaced, put a new rocker gasket on, so i was hoping that was a good service to start with.
I got a new thermostat but is did not work (back to cheap again think you are right) got a replacement and tested it in a pan on the cooker (don't tell the wife) worked fine, will fit it in the next few weeks.
other than that i don't know what more i can do for servicing the engine.
i will see if i can get a ford or lucas sender for the oil pressure light and change the oil to 20w50
thank you again
any advice and tips are always welcome may be some day i can help some one in return.
Posted: Sat Jun 13, 2015 9:10 am
by alang
[quote="spike"]Hi
fitted T adapter in block, put the new sender in and a pro oil pressure gage...[/quote]
Spike, I would like to fit a gauge, please advise exactly what bits you got and where you got them from.
Alan
Posted: Sat Jun 13, 2015 11:56 pm
by Stu_Fletch
Alan i went to Bonding & Reline Services in Thurmaston - Leicester, Earls Way Ind Estate for all the pipework for my Major. They have pretty much everything in stock you should need just take what you've got and what you need to get to and they should sort you out, Failing that A1 Hydraulics on Troon Industrial Estate also in Leics should definitely also be able to help you.
As you can see here I've T'd my oil pressure gauge in here so i can still use my pressure sender as I've fitted a different engine.
Posted: Sun Jun 14, 2015 3:25 pm
by alang
Thanks Fletch - two good resources for the note book.
Posted: Sun Jun 14, 2015 8:46 pm
by Jerry Coles
This was the set up I used for my Dexta after an engine rebuild.
http://s1106.photobucket.com/user/oldtr ... g.jpg.html
Hope this helps
Posted: Sat Jun 20, 2015 9:23 am
by spike
Hi Stu-fletch
sorry had a lot on i will get the info for you as its at home and i do all my online at work, if i can find the email i sent the guy that i got the adapter off i will post it today
got it, he also dose the testing gauge
http://www.mattlewisracing.co.uk/
Mechanics Remote Engine Oil Pressure Gauge / Testing Kit
i think the lot was about £40 with posting
they do advise to only use the gauge to test the pressure and not to run full time as the pipe may split, but i would think you can get a metal pipe with the right size fixings made up if you would like it on full time.
hope he can help, if he has not got one he knows were to get them from
Posted: Sat Jun 20, 2015 11:01 am
by Bensdexta
I got my oil pressure gauge from Matt Lewis Racing also (on ebay). Specified a 1/4" NPT adapter to screw into Dexta block. Total cost was £28. works fine, but I don't have the gauge permanently installed.
Posted: Sat Jun 20, 2015 3:09 pm
by spike
no the place to ask but how do i send a PM, i have had a go but they are just in my out box ?
any help i cant ask the panel as i cant PM
thank you
spike
Posted: Sat Jun 20, 2015 4:23 pm
by Bensdexta
spike wrote:no the place to ask but how do i send a PM, i have had a go but they are just in my out box ?
Just leave it in your outbox. It will go in due course.
Posted: Mon Jun 22, 2015 1:20 pm
by spike
thank you
