I removed the radiator and front nose from my super Dexta over 2 years ago and failed to take enough pictures because it 'looked easy'. Now I am trying to reaasemble it all with the newly recored radiator, I can't remember what was holding the top of the radiator at all,in fact I think it might have been just the rubber pipes. I did a search and found this useful post.
http://www.fordsontractorpages.nl/phpbb ... php?p=9967
I do have the pair of long brackets with angled ends which which fix to the thermostat housing, but I don't have either of the LH and RH brackets shown at the end of the above post.
Is the top of the radiator supported independantly of the nose? or do the brackets hold both with the same bolts?
The other relevant point is that I don't have a cowl, will the cooling be effective enough without it? It will be used for 1 1/2hrs topping.
Ian
Radiator mounting Super Dexta
Re: Radiator mounting Super Dexta
There's a bracket at the filler cap fixed to the nosecone.
I've no cowl and topped grass often with no problems
Thanks Brian
So from that, am I correct in reading that your radiator is just held by the rubber pipes at the top ?
I've got the filler cap bracket, if it is just supported by pipes then at least there are two and it's a rubber mounting.
Looking forward to finally getting it back together and running.
regards
Ian
regards
Ian
you are spot on Ian. Been 5 years now no probs
