Horndraulic 502 brackets
Hi. Need pictures or even better building plans for the rear brackets on Horndraulic 502. Just bought the loader, but the brackes are missing. Anybody? All best Rolf (Norway)
Re: Horndraulic 502 brackets
Yes, that's the 502.
A couple of photos of one of the brackets:
No measurements I'm afraid.
I'm looking for a pair of brackets too, so please let us know how you get on.
Thanx... Off to the scrapheap
To be continued.......
By the way. Need more pictures from all/different angles... Maybe I can work out some plans to put out on this forum
Some more photos for you.RolfA wrote:By the way. Need more pictures from all/different angles... Maybe I can work out some plans to put out on this forum
You should be able to work out the dimensions from the size /spacing of the holes. The important point is to ensure that the hole for the anti-sway bar pins are in the correct position relative to the rear axle.
Some plans would be great - Tak !
