grill without lights
Posted: Mon Jan 05, 2009 5:21 pm
by terry274
What year did the Super Dexta have lights out of the grill? That is, when were the lights mounted on the cowl?
Terry
Re: grill without lights
Posted: Mon Jan 05, 2009 7:37 pm
by Bensdexta
terry274 wrote:What year did the Super Dexta have lights out of the grill? That is, when were the lights mounted on the cowl?
Terry
According to my book Ford & Fordson Tractors, Golden Years, the New Style Dexta with headlamps in the chaff screens was introduced in Nov 1960, from serial no, 957E68356.
All the best,
Ben
Posted: Mon Jan 05, 2009 8:30 pm
by terry274
My tractor currently looks like this:
I believe it is a late 1963 or early 1964 model. Is this what the grill should look like:
I don't find grills that look like the last picture anywhere other than this picture of a sale brochure.
Terry
Posted: Mon Jan 05, 2009 8:37 pm
by Frans
The picture on the sale brochure is for the european mainland,
so all the super dexta and dexta too here in holland look that way with the ornaments in the grill, Its the same with the Super major
Posted: Mon Jan 05, 2009 8:53 pm
by Bensdexta
Frans wrote:The picture on the sale brochure is for the european mainland,
That's no use with a front loader, as the lights are in the way of the arms?
Ben
Posted: Mon Jan 05, 2009 8:54 pm
The grills in the picture are export grills used on tractors where the lights in the front did not comply with that countries law. You can see the brackets for the internal lights in your picture at the bottom of the radiator.
The grills are standard pre 1960 Dexta grills and are readily available over here. They are expensive, around £50.00 a pair.
Posted: Mon Jan 05, 2009 9:11 pm
by terry274
Are both grills the same size? Can I use the one's without light holes? I know that would not be as she came from the factory, but it would still look better than the damaged radiator look I now have...
Terry
Posted: Mon Jan 05, 2009 11:38 pm
The grills are identical. It is only the cowl that is a different shape. So you can use either grill type.
