Oil Pressure Switch
Posted: Sun Jun 04, 2017 9:42 pm
Hi All,
I recently thought I'd treat the Dexta to a proper pair of warning lights. I've got them all wired in and the charge light works fine, but the oil pressure light is doing nothing (doesn't come on ever). I've connected up to the existing oil pressure switch which I thought looked a bit odd and now guess isn't working.
Can I simply swap this out or is there something else going on here? If I told you my engine number 1420636 and date stamp L58 could anyone advise if I need 1/8 or 1/4 switch? And finally, if I replace the switch can I do it without draining the oil?
Thanks for you patience and any help.
Sam
PS: Please excuse the leak(s)
Sam
