Super Dexta Fuel Pump Drain Plug keeps leaking.
Posted: Tue Dec 05, 2017 9:29 pm
by Mervyn Spencer
Hi Super Dexta owners,
After replacing the oil in my fuel pump I cannot seem to stop the drip from the drain plug. I bought a new copper washer this week but that has not made any difference. Are there different types of copper washers for different applications? The new washer is identical to the original.
Mervyn
Re: Super Dexta Fuel Pump Drain Plug keeps leaking.
Posted: Wed Dec 06, 2017 11:21 am
by Tubal Cain
It is quite possible that the copper washer has hardened with age. Heat the washer until it is red hot and quench it in water, this will anneal the copper and make it softer.
Gerald
Posted: Wed Dec 06, 2017 8:57 pm
by Mervyn Spencer
Thanks for the tip Gerald, Ill try that in the morning. Good to hear from you again, I trust you have been well?
Mervyn.
Posted: Sat Jan 13, 2018 8:40 am
by Mervyn Spencer
Annealing the copper washer did not help
Using Donald Trumps quote calling us "Shithole countries"
, with a little skill and initiative I was able to stop the leak, now stopped since before Christmas.
Posted: Sat Jan 13, 2018 11:52 am
by Tubal Cain
Well done!
A wise man learns something new every day, and such lessons are rarely forgotten.
Gerald
Posted: Sat Jan 13, 2018 7:25 pm
by Mervyn Spencer
Thanks Gerald, just needed to remove some paint around the hole using a flat file and bingo.
Posted: Sun Jan 14, 2018 8:53 pm
by charlie63
Glad to hear you have managed to stop your leak on your fuel pump Mervyn. Sometimes it just takes a slight step back and look at things in another perspective. I learned a long time ago when fault finding to always look at the simple things first. Well done.
Posted: Mon Jan 15, 2018 9:22 pm
by Mervyn Spencer
Thanks Charlie, absolutely right. When I took a closer look at the washer I noticed a scratch/groove and the same had occurred on the new washer so that was the clue. I then ran my finger over the hole and definitely felt a ridge.
