Super dexta fuel pipework
Posted: Mon Nov 26, 2018 7:06 pm
by Mossside
Hi people
Looking for pictures of the super dexta 1964 fuel pipework as not sure if i have the correct fuel tap etc etc .
I also need pictures of the cold start pipework on the inlet manifold many thanks in advance a newbie as everything i order does not fit
Re: Super dexta fuel pipework
Posted: Mon Nov 26, 2018 7:08 pm
by Mossside
Sorry just read the rules i am from the UK
Posted: Sat Dec 01, 2018 8:45 pm
by kiwiland dexta
Hi Mossside, This is the parts list image for the Dexta fuel system, hope it helps.
Kind regards
Derek
Posted: Sun Dec 09, 2018 2:40 pm
by Mossside
Derek
Thanks for the help it maybe that i have an incorrect fuel pump as there is no where to attach the pipe from pump to inlet manifold and the pipe from fuel pump to tank is too long so this may be my problem .
Thanks for the help
Mick
Posted: Mon Dec 10, 2018 4:44 am
by PghBill
Mosside,
The pipe to the air intake comes from the primer bulb on the fuel tap under the fuel tank.It does not go to the lift pump.
Posted: Mon Dec 10, 2018 3:27 pm
by PghBill
Posted: Fri Dec 14, 2018 5:47 am
by Mossside
Thanks i have the wrong fuel tap then
