Centre Disk to Rim Bolt - Nut on outside or Inside of rim?
Posted: Fri Mar 22, 2019 9:48 pm
by Mervyn Spencer
I have noticed that some Dextas' have the bolt inserted from the back of the rim through to the outside and some the reverse of. Looking at two of my old rims which my wife has used as a planter pot, the bolt head is on the outside. I presume it is easier to remove the rim and tyre from the centre disk when the nuts are on the outside? Just my thought if the head of the bolt was inserted from the outside in your finish would look a lot neater. Sorry I seem to be a perfectionist at times, so my wife tells me :scratchhead: :wink:
Re: Centre Disk to Rim Bolt - Nut on outside or Inside of ri
Posted: Fri Mar 22, 2019 10:53 pm
by blackbob
I think it will depend on whether the disc is inside or outside the lugs on the rim.. because the bolts have a nib under their head, which fits into a notch in the hole in the disc? Hence you don't need a spanner on the bolt head?
Or do Fordsons use ordinary bolts, and it's only Fergusons which use round-headed bolts?
My wife would tell you that you are a perfectionist because you are a Virgo, like me :roll:
Posted: Sat Mar 23, 2019 10:27 am
by Mervyn Spencer
Hi Bob,
I'm far from being a Virgo but there must be a close connection to Capricorn, probably a rub off from my older brother who was a Virgo 8).
Back to the subject of the bolts, you are right my bolts have the nib on the head what a pleasure. Just had another look at my old rims in the garden and the disks are on the outside of the lugs. Thanks all the same for your input much appreciated and the bit of humour. :)
