Dexta injectors.
Mervyn Spencer
Dexta injectors.
Post by Mervyn Spencer »
Looks like I will have to replace my injectors, thought someone may have a couple gatheing dust in their workshop, obviousely I am prepared to buy them.
charlie63
Re: Dexta injectors.
Post by charlie63 »
Not so good having to replace your injectors Mervyn. Sorry I cant be of help. Neils Vintage Tractor Spares have a set on Ebay and they post International as well.
https://www.ebay.co.uk/itm/Fordson-Dext ... SwMxxdE2Cd
Charlie.
Mervyn Spencer
I did call him about 45 minutes ago and he tells me they are as is all rusty and aweful, I was tempted to buy them and hopefully make up three good ones from my old ones and those. Unfortunately to import them to me is unaffordable. Thanks all the same Charlie for the heads up its a bugger when our currency is so expensive. I have put some feelers out on this side so hopefully something will come to fruition. On second thoughts if none are available here I may bite the bullet.
Mervyn.
MikesDexta
Post by MikesDexta »
Hi Mervyn
Could you get away with just buying a new nozzle?
https://www.agrilineproducts.com/parts/ ... 27276.html
Mike
1959 Dexta
Mervyn Spencer
Thanks for your suggestion Mike, I do have new nozzles fitted. The issue is that the one injector body or head is cracked and the othe two the nozzle nut does not seal off against the head part/body and leak around the nut.
I thought I had it made with Southern Tractor Parts over in the south of England who recondition injectors if you send them across to them. I obviously misread the sales line, "Exchange Diesel Injectors, reconditioned with new nozzles and needles". Please send in your injectors for recon. Here in my part of the world when one talks about exchange service you hand over your faulty unit for a reconditioned unit at a cost. English is a complex language :eyes:
Tubal Cain
Site Expert Team
Site Expert Team
Post by Tubal Cain »
I have three injectors here which you can have. Let me know if you are interested.
Gerald
MikesDexta
Hi Mervyn
apologies I hadn't clocked that the bodies were shot. I agree with you, an 'exchange' means you send your faulty injectors in and they send refurbished, fully tested and working ones back. They should really advertise this as a refurb service.
I hope Gerald's offer works for you
Mike
1959 Dexta
charlie63
Post by charlie63 »
Mervyn,
Hopefully the offer of injectors from Gerald get you sorted out. I spent a few hours on the good old internet trying to source injectors for you without any joy. All that I could find were places offering the same service as you had already found as in send in your injectors and have them refurbished rather than an exchange service.
Charlie.
Mervyn Spencer
Gerald,
Thank you for the offer of those three injectors, I was thinking about you during my search, the reason I posted my comment "anyone have any injectors gathering dust in the workshop" maybe not the exact same words but you know what I mean. :D . I think/hope that I have located some injectors some 3hrs drive from my home. I did send the gentleman a picture of the Dexta injectors and he confirmed he can help, hold thumbs. Should that not work out Gerald I certainly will take up your offer. Nice to have you on board again, I thought you had retired from the forum like a lot of other members :wink:
Charlie, wow that was very kind of you to spend your precious time searching the internet much appreciated,I spent about three days on the net. Paul from Agriline gave me Ron Greet"s phone number on Tuesday, so I enquired from him and he got back to me saying he did have three injectors for sale. However I must thank Gerald again for offering me his injectors, some time ago he kindly assisted me with the coupler that slides between the gear box and rear transmission :clap:
Mike,
No need to apologes, I collected my 2 injectors from the specialist on Wednesday and fitted them, nice to see that only the number 2 injector is the gremlin the other two 1 and 3 seemed to be okay, for howlong I dont know.
Once I received my invoice I notice something was not right the bottom line should have been much more than what I paid. As mention earlier it was a misunderstanding from my side or badly worded on the website. I have requested a reimbursement but todate had no response.
Thanks again gentlemen for your help, :beer:
Kind regards
Mervyn.
Good luck to your rugby teams this weekend.
bobfaecullen
Post by bobfaecullen »
Hi All,
I too have a need for one injector for my vineyard dexta, same problem as yours Mervyn, there is a leak from between the 2 parts and for the life of me I cannot see why, I've had it apart several times and compared it with the 2 good ones but still can't see what the problem is.
Once Mervyn gets sorted with his needs and if Gerald still has a spare injector, can I buy it from you please.
Bob
Mervyn Spencer
Hi Bob,
On my injector that is leaking there appears to be a fine crack/fracture alongside the one pin on the body side side that fits into the nozzle also one of the two pins on mine have broken off, that maybe a similar issue with yours the fracture I mean..
With regards Gerald's kind gesture, please feel free to communicate with Gerald I'm sure he will oblige what a generous man :clap: . I'm hoping that I also will only require one injector, which I trust will be available as per my conversation with a specialist here in South Africa. I wish you well in sorting your issue out Bob.
Mervyn.
Tubal Cain
Site Expert Team
Site Expert Team
Hi Mervyn,
I haven't retired, it's just that I don't log in to this site as often as I use to.
Bob I will see how many injectors I have and see if I can spare one for you. I will get back to you in due course.
Normally if there is leakage from the cap it is due to the mating faces being damaged, both the nozzle and the body should have a mirror finish as they are a face to face seal.
Gerald
bobfaecullen
Hi Gerald,
Thank you, I will await your message. The 2 faces are definitely not a mirror finish, so I guess that is the problem, I think someone has been in there before me.
Bob
Tubal Cain
Site Expert Team
Site Expert Team
Mervyn/Bob,
I have a set of three for Mervyn, should he need them and one for Bob. I will test them to make sure that they are sound before I dispatch them. They weigh approximately 500gms each.
I look forward to hearing from you.
Gerald
bobfaecullen
Hi Gerald, have sent you a pm
Bob
Mervyn Spencer
Hi Gerald
I trust that you are keeping well and ready for your winter. I sent my one injector off to the local guy some three hours away from me who said he may be able to help, I did contact him yesterday and reported that he was busy with my injector. I won't hold my breath though. Thank you again for offering to hold on to your injectors for me, I will let you know as soon as I have received it back and tested it out.
Mervyn.
bobfaecullen
Hi Gerald,
Injector arrived this morning, fitted and working perfectly. Once again thanks.
Bob
Mervyn Spencer
Nice to hear Bob I'm pleased for you.
I am starting to dought this dude who said he may be able to assist me :( .
Gerald, I will wait till next week and if still no news, I shall be cap in hand for your assistance. Gerald, did you use Royal Mail to mail the injector to Bob or was it through a courier?
Mervyn.
Mervyn Spencer
Mervyn.
Tubal Cain
Site Expert Team
Site Expert Team
Bob/Mervyn,
I'm pleased to hear that the injector arrived safely and is working fine. I posted it from our local Post Office using Royal Mail, I'm not sure if it was the cheapest but, most convenient.
Mervyn what ever you decide, the injectors are here waiting for you.
Take care.
Gerald
Mervyn Spencer
Good evening Gerald, thank you very much again for the offer. I'm hoping to hear from this guy tomorrow sometime or I will call him and put some pressure on him.
Thank you also for indicating the means of shipping Gerald.
Kind regards
Mervyn.
Mervyn Spencer
Good afternoon Gerald, is it convenient to PM this afternoon please? This guy up country from me is not able to help me :(
Thanks Mervyn.
Mervyn Spencer
Hi Gerald, I have made an attempt to send you a PM, you may receive two, I think I made a hash with the first one.
Mervyn.
Mervyn Spencer
Hi Gerald,
I sent you an email a short while ago letting you know that I received the three injectors this afternoon. Not sure if you are getting my emails. Thank you very much again.
Mervyn Spencer.
Mervyn Spencer
Good morning Gerald, apologies for lack of information, I am still waiting for my injectors from the service guys, absolutely hair pulling frustration :x . Hopefully I shall get some news by tomorrow.
Mervyn.
