fordson dexta injection pump
I have just acquired a Fordson Dexta in rough that I plan to get back into working condition. I ordered a starter, service manual and filters I still haven't received my manual otherwise I would probably know the answer to my question by now. On the fuel injection pump there is a arm on the engine side of the pump what goes on that arm and what is its function. My tractor just has a long zip tie and a rope on that arm. One more question is there another way to find the serial number of my tractor other then the data plate mine is missing.
Re: fordson dexta injection pump
Malcolm,
Your lever on the injection pump is the stop lever for stopping the engine, hence the piece of rope.
You tractor serial # is found stamped in the gearbox bellhousing next to where it mates to the engine. If you are sitting on the tractor it is at the left-hand side. If you look at one of my replies to a previous posting you will also see the location of the various casting codes. If you get these I can date your tractor for you.
Charlie.
Charlie.
