Corrosion in cooling system
Started stripping down engine today amd noticeced they the there was quite bad corrosion in the cooling system , should I be attempting to sort this or is it quite normal?
Re: Corrosion in cooling system
It's quite normal, especially if anti-freeze isn;t strong enough..
1440276 - 1957 - working
1335674 - err - one day..
Ford 7710 2wd, 1983 - working
Thanks just need injectors done and see if it starts again
