1958 Dexta idling adjustment
Tim Comer
Post by Tim Comer »
The idling speed has slowly increased over the last twelve months or so, the adjustment on the air intake was to the minimum so I adjusted the control rod adjacent to the battery to get the idle speed to about 650 ish, but when working there is now a slight reduction in power output, can anyone advise another method of adjustment?
Regards Tim.
PghBill
Re: 1958 Dexta idling adjustment
Post by PghBill »
Tim,
Sounds like you might have a governor problem. Do you have a pneumatic or mechanical governor? If it's pneumatic, the diaphragm might be leaking or the spring is weak.
Bill
Tim Comer
Post by Tim Comer »
Hi Bill, thanks for replying, i think its a pneumatic governor.
Tim.
