Does anyone have the torque setting for the deferential bolts on a 1959 Dexta? I can’t see it listed in the online manual,
Your help would be appreciated.
Thank you
Rear axle torque settings
Re: Rear axle torque settings
Dear Trevorthetractor
According to my Fordson Dexta Workshop Manual, Section 7, Rear Axle, Reassemble the Differential, it says: "Tighten the eight casing bolts to a torque of 70 lbs ft and lock with wire".
Hope that is what you are after.
TimE
TimE
Yes it is thank you.
