silly question some might think but i dont seem to
find it any where, standard 600x 16 fronts no loader or wheel weights
any one
tyre psi
Re: tyre psi
From my "Dexta and Super Dexta Operators Handbook" under genral specifications- wheels and tyres.
Front tyres. 6.00 X 16 20psi.
Front tyres. 6.00 x 16 (with weights) 20 psi.
Mervyn.
Mervyn.
Re: tyre psi
thanks mervyn, just what i needed
Re: tyre psi
Always a pleasure Skyblue.
Re: tyre psi
Strangely, my Dexta Instruction Book lists pressures as follows;
5.50x16 20 psi.
5.50x16 26 psi (with weights)
5.50x16 20 psi.
Re: tyre psi
on 19" rims the pressure has to be 34 PSI / 42 PSi when front wheel weights)
on 16" rims the pressure has to be 20 PSI / 26 PSi when front wheel weights)
The difference between the 6.00 and 5.50 tyres is neglectible.
Rgds
Jos
Jos
Re: tyre psi
Thanks for the correction Jos obviously a misprint in mt operators manual
