Hand brake malfunction
AlexB
Post by AlexB »
Morning all
Handbrake on my super Dexta isn't staying on
It seemed fine when I had the mudguards on, but now I have swapped to the cab ( I can't remember the make, but it has canvas roof and doors ) it won't stay on
Is there a different model mechanism for the cab or might it be knackered and replacement needed - if so, which bit or do I need ratchet, rod, spring, pawl and all ?
Many thanks in advance
Bluebilly
Re: Hand brake malfunction
Post by Bluebilly »
I had a similar problem when I fitted a new handbrake to my Dexta. It took a few attempts to get the angle of the toothed bracket correct so that the pawl didn't slip. I had to make the holes in the mudguard oval to get the correct adjustment. You may have the same issue if it was working ok before you changed to the cab.
1948 E27N
1958 Dexta
Roadless 75
TEF 20
MF135 multipower
MF 165
MF 240
SAME Solar 60
AlexB
Post by AlexB »
Thanks mate !
