Dexta diesel tank
Posted: Mon Nov 09, 2020 7:33 am
by Scoobynorm
Hi, restoring dexta at the moment, when refitting diesel tank is there any need to place pad between the tank and where it bolts on with the 3 bolts ( like the way the radiator is done with the 2 pads)
Re: Dexta diesel tank
Posted: Mon Nov 09, 2020 12:44 pm
by Billy26F5
Yes, they should be 3/16" thick, otherwise the dash won't fit properly.
Posted: Tue Nov 10, 2020 7:32 am
by Scoobynorm
Do you know where they can ne purchased
Posted: Tue Nov 10, 2020 7:39 am
by Scoobynorm
If theyre not readily available to buy, would it be ok to make from piece of rubber approx 5mm thick
Posted: Tue Nov 10, 2020 11:40 am
by Billy26F5
These rubbers aren't available, your idea would be fine.
