New thermostat sender different to original.
Posted: Mon Apr 05, 2021 12:40 pm
by Mervyn Spencer
Hi Folk,
I bought a replacement thermostat from Sparex around 2005 and have never used it as my original one was still functional. However yesterday I pulled out the new thermstat and the sender unit it totally different and although the nut fits and tightens up the part of the sensor that passes thru the nut does not tighten and coolant leaks out. My original sensor still seals perfectly.
http://postimg.cc/cK3xww6P
Re: New thermostat sender different to original.
Posted: Mon Apr 05, 2021 12:45 pm
by Mervyn Spencer
http://postimg.cc/0bkTPDvP
Apologies, my posting of pics is very bad.
Posted: Mon Apr 05, 2021 12:48 pm
by Mervyn Spencer
The old sensor is on the right of my pic, quite oviouse from the colouration.
Posted: Mon Apr 05, 2021 1:18 pm
by Billy26F5
There's a case of not making something to the correct design and failing as a result. Repro parts can be very bad in that sense. I recommend you look out for an original temp gauge if you need a replacement.
Posted: Mon Apr 05, 2021 1:53 pm
by Mervyn Spencer
Thanks Sandy, you are right re the correct design. No idea where they got this design from. I did note the difference those years back but did not take to much note as the original one still is good. I will keep an eye open for the correct part and keep the replacement as an ornament.
Mervyn.
Posted: Fri May 14, 2021 2:30 pm
by Mervyn Spencer
I see that there are new thermostats around with the original sensor, but Sparex are still selling the same one that was incorrect for my Dexta. I think they need to correct that issue of theirs. Unless other members have had no issues fitting the Sparex guage?
Posted: Fri May 14, 2021 6:13 pm
by Billy26F5
I think you'll find all suppliers needing to sort their parts for not matching the Ford spec. I think it's better to find good second hand parts if possible.
Posted: Sat May 15, 2021 9:32 am
by Mervyn Spencer
Again thanks Sandy, not too many Dextas left here all been sent to china
. As I mentioned in my previous post my original guage still works.
Mervyn.
