starter engagement
Posted: Sat Mar 21, 2009 11:09 pm
by terry274
I had the starter rebuilt on my Super Dexta, the man that rebuilt it replaced the clutch nose mechanism with a ratchet type mechanism. He said this type was more durable than the original.
About once out of every ten times when I go to start the tractor the teeth of the starter will not mesh with the ring gear. The starter teeth hit the ring gear teeth square on rather than engaging together. I have to put the tractor in sixth gear and rock the rear wheel to move the engine slightly, then everything works well. Is this something that occurs with the original starter mechanism? Is there any adjustment to get the starter to begin to turn right as the starter gear reaches the ring gear?
Terry
Posted: Thu Mar 26, 2009 1:09 am
by terry274
I found that I could touch a wire to the starter terminals for an instant to get the starter to move enough that it would engage. Not the best solution, but it does work.
Terry
Posted: Thu Mar 26, 2009 2:01 am
by commander
Terry, you can get some adjustment on the relay operating switch mounted on the starter. It is mounted on a threaded spigot, you can turn this in/out to adjust the engagement point. At least it works this way on the older style starters.
