Dexta Electrical Diagram
Posted: Thu Sep 23, 2021 7:24 am
by duffincart
Does anyone have a diagram for dexta wiring that has a five terminal lucas regulator,
F,D,E,A and the extra one (A1) my set up also has light switch and key switch combined.
I think the five terminal is the older regulator. I am not sure if the isolator key switch being separate or combined is the original set up, my dexta is early 1960.
I think i have it sussed using the section 9 electric diagram in the online manual, that has four terminal regulator and separate key sw isolator though.
Kind regards
Re: Dexta Electrical Diagram
Posted: Thu Sep 23, 2021 7:40 am
by Billy26F5
I've posted the old diagram elsewhere, here's where it came from.
viewtopic.php?f=12&t=8328
Posted: Fri Sep 24, 2021 12:02 pm
by PghBill
Posted: Fri Sep 24, 2021 12:19 pm
by Billy26F5
If you use "hotlink for forums" instead of "thumbnail for forums" for posting a pic it will appear full size.
Posted: Sat Sep 25, 2021 6:50 pm
by Mervyn Spencer
Folk I'm sorry to hijack this post, been a bit dim lately. Please can you confirm for me that the numerals on the RED wires on the diagram eg. #2 from starter motor to solinoid and #3 from coil terminal on cluster switch to other terminal on starter motor?
Posted: Sat Sep 25, 2021 9:07 pm
by Billy26F5
It's exactly as you say Mervyn.
Posted: Sun Sep 26, 2021 9:33 am
by Mervyn Spencer
Thank you Sandy, sorry another question, is there a diagram for the separate key switch? I am planning on introducing a indipendent switch later on.
Posted: Sun Sep 26, 2021 10:13 am
by Billy26F5
Here's the manual with the late diagram near the end.
http://www.smallholderservices.co.uk/si ... electrical
There's also a service letter describing the new switch, I can post it if needed.
Posted: Sun Sep 26, 2021 5:23 pm
by Mervyn Spencer
Thank you Sandy, your are such a star, I notice that on the wiring diagram you sent me there is no connection point for the rear lights, however I do have a spare light switch only with all the light connectors, I'm sure the service letter will explain all that. Please I would love a copy of the service letter Sandy.
Mervyn.
Posted: Sun Sep 26, 2021 7:34 pm
by Billy26F5
Service letter coming next post I'm afraid.
The side/rear lights and number plate light (and socket) connect to the S.T. terminal on the light switch.
Posted: Wed Sep 29, 2021 9:59 pm
by Billy26F5
Posted: Fri Oct 01, 2021 7:55 am
by Mervyn Spencer
Good Morning Sandy, thank you ever so much for coping me the service letter, I am sure it will be very helpful. Do have a wonderful day.
Mervyn Spencer.
