Dexta Sump Removal
Manta356
Dexta Sump Removal
Post by Manta356 »
I'm trying to remove the Sump of my Dexta.I've removed all bolts as far as I can see,Including the 2 Longer ones at Front and Rear,Although one of the Front Bolts is still in-situ as the nut come off and the stud is still in Place.
I've tried to remove the Sump but I'm wondering is the Sump on Dowels at the Gearbox end and the Stud at the front is Preventing it's Removal.Or Should the Sump Drop down over the Stud that's still in-situ.
The Engine is Still on the Tractor.
Re: Dexta Sump Removal
Did you remove the front axle carrier?
Manta356
Post by Manta356 »
Yes
The sump should just drop down, recheck you have actually removed all bolts and nuts (including the ones on the adapter plate), then gently ease it down, it is a bit on the heavy side as it's cast iron.
Manta356
Post by Manta356 »
Tried Prising it again and it Dropped off.Must've been Stuck to the Gasket.
Thanks for the Replies
