ok so saw the Dexta today.
Phone died so couldn't get a video or more photos.
Hydraulic lift was ok moved smoothly and held in the raised position with a large rear bucket on it, don't know if that would have been heavy enough to present lift problems.
It has the Minimec fitted to it.
Double clutch, live pto. Drove it around and brakes seemed ok, clutch seemed ok but first time I have ever used one like it, so who knows.
There was some grinding noise when changing some of the gears (like getting it into first took a couple attempts), didn't know what to make of that since my friends 2009 Kubota does similar. Gear sticks seemed in good condition.
Rims seemed good but the tyres had cracks in between the treads. and a split on left hand side rear tire. So they will probably need replacing at some point. Valves seemed solid when giving them a wiggle.
Getting in to second from first it was fine, no noise, went straight in.
Exhaust when running was clear the whole time, a little puff of thin white smoke on start. Was expecting more to be honest
Oil dipstick looked pretty dark. Don't think filters have been changed in a while.
Owner claims to have had it for a year and has no use for it. Claimed he has two petrol Fergusons and he is a "Ferguson man" and if he was going to do one up he would rather do those up.
He said he used it for topping and moving stacks of wood. The original photos posted show it attached to the wood splitter I believe, which shows as sold in his facebook market place history.
He said he bought it along with lots of other equipment when he found it in someones barn along with a PTO driven wood splitter and other equipment, when on a job.
Proof meter had ~8640 hours on it, but he said with the age of it cant be right and must of been replaced at some point.
Proof meter looked like it was functional when driving it.
Throttling seemed to work as expected.
Fan and fan belt seemed ok.
Rubber tubing looks like it could do with replacing for the radiator
He thinks it had a paint job early 2000's.
Didn't notice any welds on the axles, engine block or 3 point linkage arms.
Rubbers worn and split on the front axle joints and steering arm joints.
Steering took about 2- (max 3) inches before engaging the wheels. Didn't veer off when driving and letting go of the steering.
Throttle up and down sounded ok to me and no smoke whatsoever on exhaust when moving it up and down.
Now for the obvious bad parts:
Water leaking from the front and collecting in the frame under the radiator. Didn't seem to come from the radiator itself but the connections, he claimed it was from the water pump? water didn't look hot when it came out.
Couldn't really look in the radiator fluid because the hose bends under the bonnet so couldn't really see into it.
Fuel tank had some rust in the bottom when looking in with a torch, wiped finger around the top inside round fuel cap and finger came out with a little brown. but not as much as i was expecting it.
Primer pump didn't work and didn't see a cold start. Seemed to start ok the three times we started it, but it would have warmed up by then.
Don't think heating element worked for the manifold?
Temp gauge was non functional missing connection from the gauge to the thermostat?
He claimed to have used it through summer and didn't overheat but obviously not much you can do with a claim like that.
He came out and said that he used a pump of gas (ether) to start it first time but that it ran fine after it. With the missing pump not sure how cold start would work, heard of syringe of diesel but he seemed like the type of person to take the easy option and be done with it.
He grew up on farms in Scotland with Dextas or Super Dexta (can't remember which) for working slurry or something he claimed.
He acknowledged it wasn't the wider german special although the bonnet had the sticker of a Dexta special painted over. probably a doner bonnet? But makes the paint job a little suspicious since you would expect someone to remove that before painting over it if it was a proper job.
I liked it and it drove well. But the ether cold start and the water leak issue without being able to see the temp gauge especially were downers.
How much damage could he have done to it using ether for last year on cold starts? is that a complete no?
I think given the price being on the high side like you mentioned you guys would probably give it a wide berth.
Looking online you can get the newer primer pump set up which taps into return line:
https://old20tractorparts.com/fuel-syst ... 0206k.html
Remaining real concern is whatever was going on with water up the front, unable to judge what was going on with the temp and obviously him taking the ether cold start route as his work around for the broken primer.
Temperature over here was around 5-7 degrees C when I looked at it.
He seemed pretty forthcoming with the problems with it, no doubt there will be more hidden behind the ones discussed.
On a scale of 1-10 how daft would I be to take a punt? Im willing to put in 1500 euros within the next year to repair the issues mentioned, if repairable, since that is what I was looking at for a measly ride on mower (3700ish) that would not be up to task any way.
I didn't get the impression that it could not be put right if the starting system was renewed but I cannot judge how much damage would have been done by the ether though.
So much to think about when viewing, it's pretty full on. Should of taken photos and videos, damn it
