Bush hog drifts downward
Posted: Tue Jul 11, 2023 7:04 pm
by Girardo
I have 1964 Super Dexta I have owned since 1989. It has been a good tractor and about 13 years ago I split the tractor, replaced all oils seals, hoses, gaskets, checked rod and main bearing clearances, replaced the brakes, etc. It has always had one nagging problem. When Bush hogging it always drifts downwards. If anyone could lead me in the right direction as to the cause, I would appreciate it. Thanks
Re: Bush hog drifts downward
Posted: Tue Jul 11, 2023 7:23 pm
by Billy26F5
Not too sure if I know what your problem is, sounds a bit like a leak in the hydraulics but that's as far as I can go without more details.
Posted: Tue Jul 11, 2023 8:31 pm
by Girardo
Thanks. I will keep looking into it.
Posted: Fri Jul 14, 2023 10:34 pm
by kiwiland dexta
For what it's worth, this is from the repair manual.
Hope it helps!
Posted: Sat Jul 15, 2023 2:46 am
by Girardo
