tipping trailer for a dexta
Posted: Tue Apr 14, 2009 10:30 am
by GERRY
I am trying to acess the proper weight that i can pull with my dexta on the public road the trailer ihave is a wooden single wheel with 10 ply i think old army type tyres, on the tyres it says load at 65 psi 3525lb, i think the trailer is a ferguson or a weeks type ,it was known as 3 or 4 ton tipper probely from the 50s.the ,does this sond correct for this axel and tyers dexta pulls this with no bother, Also does any one know where i could get studs for these old wheels they are old split rimswith 8 studs, one side of axel is left hand and the other is right hand thread, ihave rung off acouple of the studs before i relised this hence the ? hope someone can enlighten me with this one, Gerry
Posted: Tue Apr 14, 2009 2:57 pm
by Jos Cuypers
Gerry,
I'll check the "technical inspection report" . I went with my dexta to the technical inspection some time ago, but if I remember well : MTM = ± 6 000 kg.
You can also call the "Inspection Mobile" or "Autokeuring", they have tables for this.
Posted: Tue Apr 14, 2009 9:33 pm
by GERRY
Thanks Jos for your reply, that would be helpful, i think the most i would be pulling would be around 3000kg. so if you are correct it is well inside . Would you have any idea on the single wheels on this type of trailer are they also inside spec. Gerry
