Ford hydraulic components need identifying
Roadless63
Post by Roadless63 »
Came accross the following bits whilst on the trail of some fordson spares the other day, I have no use for them but don't really know which model they're from either! I guess something from the 1000 series (possibly 3000?) anyone recognise them?
There are two lots of pipework/braketry which have the part numbers C9NN N902B and D2NN P937A.
No part number for spool valve I'm afraid.
Many thanks, Ed
You are right about the pipework but the valve does not look like it fits on a British Ford or Fordson.
Lesfen
Post by Lesfen »
Ed,
Found the C9NN N902A part number in a manual for:
3000-SERIES 3 CYL TRACTOR (1/65-12/74):
C9NNN902B AR Kit, Pipework & Coupling w/Deluxe Seat, Includes: Ref. 1 thru 13, NH-E Only, No Longer Serviced, Start
Year: 04/01/1969
Also for 2000 and 4000-Series.
Unable to trace the D2NN P937A but from what I have read the first 4 positions point to a Ford tractor part first used in 1972.
Cheers,
Les
Lesfen
Post by Lesfen »
Ed,
Found the D2NNP937A part number this morning:
5000-SERIES 4 CYL TRACTOR (1/65-1/75)
05H03 SINGLE & DOUBLE ACTING PIPE & COUPLING KITS, ACCESSORY (U.K.) - 5000
D2NNP937A AR Kit, Auxiliary Service, Includes: Ref. 1 thru 12, NH-E Only, No Longer Serviced, Start Year: 01/01/1972
Looks like it was meant only for the 5000.
Have not seen a stackable spool valve like that in any of the tractor manuals.
Les
Roadless63
Thanks for info on the pipe/brackets. I've no idea what the spool valve is off either, other than it's definately a ford of some description as it comes in a ford plastic bag. I'll have another check for part numbers.
thanks again!
Ed
