Ford hydraulic components need identifying
Posted: Sun May 11, 2008 11:18 pm
by Roadless63
Came accross the following bits whilst on the trail of some fordson spares the other day, I have no use for them but don't really know which model they're from either! I guess something from the 1000 series (possibly 3000?) anyone recognise them?
There are two lots of pipework/braketry which have the part numbers C9NN N902B and D2NN P937A.
No part number for spool valve I'm afraid.
Many thanks, Ed
Posted: Mon May 12, 2008 7:56 am
You are right about the pipework but the valve does not look like it fits on a British Ford or Fordson.
Posted: Wed May 14, 2008 6:00 am
by Lesfen
Ed,
Found the C9NN N902A part number in a manual for:
3000-SERIES 3 CYL TRACTOR (1/65-12/74):
C9NNN902B AR Kit, Pipework & Coupling w/Deluxe Seat, Includes: Ref. 1 thru 13, NH-E Only, No Longer Serviced, Start
Year: 04/01/1969
Also for 2000 and 4000-Series.
Unable to trace the D2NN P937A but from what I have read the first 4 positions point to a Ford tractor part first used in 1972.
Cheers,
Les
Posted: Wed May 14, 2008 3:52 pm
by Lesfen
Ed,
Found the D2NNP937A part number this morning:
5000-SERIES 4 CYL TRACTOR (1/65-1/75)
05H03 SINGLE & DOUBLE ACTING PIPE & COUPLING KITS, ACCESSORY (U.K.) - 5000
D2NNP937A AR Kit, Auxiliary Service, Includes: Ref. 1 thru 12, NH-E Only, No Longer Serviced, Start Year: 01/01/1972
Looks like it was meant only for the 5000.
Have not seen a stackable spool valve like that in any of the tractor manuals.
Les
Posted: Mon May 19, 2008 6:50 pm
by Roadless63
Thanks for info on the pipe/brackets. I've no idea what the spool valve is off either, other than it's definately a ford of some description as it comes in a ford plastic bag. I'll have another check for part numbers.
thanks again!
Ed
