2712E engine
2712E engine
I seem to remember you saying once, that if you were to repower a Major, you would recommend using a late model engine, (the one with the injector pump mounted directly to the timing gear cover)
Why, and what would the advantages over using a later model Super Major engine.
I have come across a Ford Industrial engine model 2712E. Is anybody able to give me any info about these engines.
Have been able to find info about 592 etc, but not much about the 2712 models.
Kiwi Kev
Kiwi Kev
"Classic Contracting"
International 784 4WD
& looking at another tractor!
The 2712 is very similar to the Super engine with the advantage of dry liners and more HP. It also has the direct drive injection pump as you say. From what I remember it will bolt straight up to the Super clutch housing although the axle support will be the usual problem.
There are also better injector seals as well.
They were excellent engines and in mine and other ex -Ford mechanics, would have been the ideal engine to power the 5000 instead of that rubbish over square thing they fitted!
Everyone wants to put 6 cylinder engines in but I still would like to see one of those fitted. There was a brand new one at the college where I taught, it just laid there in the sundries bin doing nothing. I tried to convince the head of engineering to fit it to an old Super but without success. It would have been a great project for the students.
Thanks for that.
Do you know approx HP.
Are you saying it will bolt straight up to gearbox etc, just need to sort out the front axle support
It is out of boat, so has all the marine manifolds and hydrualic drive on it.
Kiwi Kev
Thanks for that.
Kiwi Kev
2712E
Hi Kev, I have a Super Major which has had one of those fitted a long time ago. I have had it for a couple of years but have not done anything to it yet.It is a future restoration job as it was seized up when I got it because it had been used as a travelling Irrigator anchor, getting wet every day. The oil filter is too wide for the chassis channels so they cut a piece out of the webs and fitted another channel back to back to strengthen it. On the other side the crankcase breather also fouls the channel but it would be quite easy to modify it. The Oil filter housing could also be modified to make it fit or a spin-on filter housing head fitted. The clutch housing seems to be identical to the Fordson motor. The front axle support has been modified and turned around to the front and a bracket fabricated to bolt onto the front casting. Brian has described this bracket previously. They have fitted a long ugly radiator hose to transfer from one side to the other instead of just changing the radiator pipes. It is not a very complicated conversion but I feel this one could have been done better. Best regards - Michael.
I have e Ford 2709E engine. I did a complete overhaul to the engine, but now i need the specifications to adjust the dieselpump. Does anybody has a service manual for these kind of engines, or knows where I can get one?
Thanks,
Arno Gubbels
Thanks,
Arno Gubbels
Grani, Thanks for the manuals and parts list. But I can't find the Timing of the injection pump of my type of engine (2709E).
Can I use the timing specs of the 2715 engine, it has a bore of 107.21mm while mine has a bore of 104.77mm, I don't know if this is relevant for the timing of the injection pump. Or does someone else knows where I can find this timing information?
I fitted something similar to our old Major based Weatherill loader. IIRR there was one bell housing bolt that did not match up. The main mod was that the side rails would not fit, particularly on the oil filter side. Have since seen a very neat dog-leg arrangement for this. The sump was wrong for the axle tie . I got around this on the loader by suspending the engine from the bell housing only. It work for years like that. (Early Chaseside shovel did not have front engine mounts). Just had to put some thrust plates on the steering axle. Of course it would be a different job in a tractor without the shovel frame.
It did tranform the old machine into something quite lively that would work all day.
There is a 2700-series engine that's four cylinders, right? Now, would it be possible to simply bolt on the oil-pan from a Fordson Major engine onto that one or is it impossible?
