i had noticed a thinning of sump oil.
i have removed rocker cover and found a small diesel leak around number 3 injector, i will change all copper washers on return pipe,( appears to have no cracks), is this all there is to do, and how can i check if there are no more leaks?
thanks brett
ps engine is a 380cid as far as i know.
pps does anyone have tappet clearence values for this engine and can i do them cold whilst rocker cover is off?
i have got new copper washers for diesel pipe and will fit on saturday, also will do tappets, Brian gave me clearance values but how do i know which is inlet and outlet?
thanks brett
i have mended the leak i hope, checked tappets they all seemed fine, good job as i could not work out how you adjust them, they only have a hollow bolt no nut and screw head,
the hollow bolt is locked in postion but i could not see how.
