ford 3550
snowman
ford 3550
Post by snowman »
hi new to forum we have a ford 3550 ex loader tractor, minus the loader now which is i think is a 4000 under the steel cowling ?. Been stood many years she,s a 1975 reg hopefully back running at wk end . my question is she has 3 forward gears in low box and 3 in high box, but she has 2 reverse gears in both low and high box? is it poss to convert her to a standard 4000 gear box she.s only done 300hrs and we,d like to use her a bit more as a agri tractor any help gratefully recived thanks
Mike J
Re: ford 3550
Post by Mike J »
The 3550 was based on the 3000 with a six speed box with a reverse in both ratios. The 4000 was used in the 4550.
Never seen two reverse gears in both ratios.
Mike J
