I have recently bought a Ford 3000. I am having a bit of trouble figuring out the numbers on the bell housing area. They read like this:
6M22C
7A12
A146-946
Can anyone help me identify these numbers, as I cannot make any sense of them, especially the serial number?!
Your tractor was built on the 22nd December 1966, in the afternoon in the Antwerp factory. The second number is January 12th 1967 and the "A" number is the serial number which gives Antwerp.
The model number is usually the last to go on as the tractor leaves the factory so the January number is slightly out of series but it could have been the Christmas celebrations>
the '000nd Series was known as The World Series and, in theory, was the same tractor all over the world. Parts and tractors were made at Basildon, tractor assembly, engines and hydraulics, Antwerp, tractor assembly, gear boxes and rear axles, Highland Park, USA, tractor assembly, Select-O-Speed transmissions.
So Basildon made engines and hydraulics for the whole world, Antwerp the gearboxes and rear axles for the whole world and Highland Park the SOS transmission. So you could have a tractor assembled in any of the three factories and it would be built with parts from the others. Serial numbers tell you where the tractor was assembled. A = Antwerp, B = Basildon, C = Highland Park. As far as I know Antwerp is still producing tractor components for CNH, Basildon still assembles some models.
