hello all
am thinking about fitting some double acting spool valves to my 4000 if i port off the auxiliary and return return feed via tapping the filler plug my question is if i put the auxiliary switch in the middle , lift arms and auxiliary would i be able to use both at the same time , wanting to use a reverse-able plough would this be possible? any tips would be great, not too hot on hydraulics
thanks wayne
4000 hydraulics
4000 hydraulics
i love driving tractors me!
Re: 4000 hydraulics
Fit an adapter like this under the plate on the lift, use a spool with power beyond capability. then you can have as many DAR outlets as you want without messing up the tipping pipe. Spools will also function correctly without messing up the 3-point linkage.
frode
1957 County MarkIV Crawler
1964 County Super-4
1967 County 654
1977 County 7600-FOUR
1964 County Super-4
1967 County 654
Re: 4000 hydraulics
sorry, I forgot to post the linkshergar wrote:fit what type of adaptor frode?
here it is:
http://www.ebay.com/itm/hydraulic-adapt ... 4ab4118c91
frode
1964 County Super-4
1967 County 654
1964 County Super-4
1967 County 654
Re: 4000 hydraulics
ok when you mean under the plate on the lift does this adaptor go under the auxiliary switch just under the seat ? sorry if i seem a bit dumb don't know much about hydraulics but learning fast!
Re: 4000 hydraulics
yes, under the plate.shergar wrote:ok when you mean under the plate on the lift does this adaptor go under the auxiliary switch just under the seat ? sorry if i seem a bit dumb don't know much about hydraulics but learning fast!
frode
1964 County Super-4
1967 County 654
1964 County Super-4
1967 County 654
Re: 4000 hydraulics
thanks for the info frode
dose any one know if i get one in the UK or do i have to get one shipped from the US?
thanks wayne
thanks wayne
