4000 hydraulics
Posted: Fri Feb 24, 2012 10:22 pm
by shergar
hello all
am thinking about fitting some double acting spool valves to my 4000 if i port off the auxiliary and return return feed via tapping the filler plug my question is if i put the auxiliary switch in the middle , lift arms and auxiliary would i be able to use both at the same time , wanting to use a reverse-able plough would this be possible? any tips would be great, not too hot on hydraulics
thanks wayne
Re: 4000 hydraulics
Posted: Fri Feb 24, 2012 11:19 pm
by frode
Fit an adapter like this under the plate on the lift, use a spool with power beyond capability. then you can have as many DAR outlets as you want without messing up the tipping pipe. Spools will also function correctly without messing up the 3-point linkage.
Re: 4000 hydraulics
Posted: Sat Feb 25, 2012 7:19 pm
by shergar
fit what type of adaptor frode?
Re: 4000 hydraulics
Posted: Sat Feb 25, 2012 7:24 pm
by frode
shergar wrote:fit what type of adaptor frode?
sorry, I forgot to post the link
here it is:
http://www.ebay.com/itm/hydraulic-adapt ... 4ab4118c91
Re: 4000 hydraulics
Posted: Sat Feb 25, 2012 8:01 pm
by shergar
ok when you mean under the plate on the lift does this adaptor go under the auxiliary switch just under the seat ? sorry if i seem a bit dumb don't know much about hydraulics but learning fast!
Re: 4000 hydraulics
Posted: Sat Feb 25, 2012 8:02 pm
by frode
shergar wrote:ok when you mean under the plate on the lift does this adaptor go under the auxiliary switch just under the seat ? sorry if i seem a bit dumb don't know much about hydraulics but learning fast!
yes, under the plate.
Re: 4000 hydraulics
Posted: Sat Feb 25, 2012 8:09 pm
by shergar
thanks for the info frode
dose any one know if i get one in the UK or do i have to get one shipped from the US?
thanks wayne
