As you can see the lower of the two frost plugs at the back of the block is leaking.
Trying to replace the frost plug without spliting the tractor would nearly be as hard as reseting the valve clearances after retorquing the heads on a TS 3
Apart from that, the clutch plate is Ok, but the pressure plate is worn out as the pto plate is perminantly bonded to it. TSG.
