Ford 3000 not responding
Posted: Thu Oct 06, 2016 10:43 pm
by ford7600
Hi All
I own a 1975 Ford 3000 ( one of the last built I think) the problem is that when I select the hydraulic lift to lift ,it don't ,not straight away anyway and will take 30 seconds or even up to a few minutes to lift. The only thing that I do know is that just after the lift has been selected to lift you see a slight movement and then nothing . Can anyone tell whats the cause and how to put this right as its anoying . But seems to lift reasonable when lift is not under load when nothings on the linkage , I only found this out when I attached a plough to the 3000 the other day.
Re: Ford 3000 not responding
Posted: Fri Oct 07, 2016 11:11 am
by blackbob
I'm only guessing as I never worked on a 3000, but assuming you have no leaking pipes on the suction side of the [engine-mounted] pump, I'd be inclined to think there are clues in this old thread: http://www.fordsontractorpages.nl/phpbb ... lter#p7994
