4000 4X4 Transfer
Posted: Sun Feb 01, 2009 3:09 pm
Busted. Cracked. Need part.
The collar that mates to the tractor housing and to the transfer emergency brake housing is cracked. Backed into a stump.
Part is called, from the research I have done; a pinion housing.
It looks to be listed in the Ford Part manual in FIG 02B01.
E3NN2N595BA Pinion Retainer assembly. Used on all models with 4WD except 5000. Item # 1.
It is a simple part. I had checked at the Ford Dealer, and at least the emergency brake disk # 15 E9NN2N625AB was available.
My problem is the picture of the item in FIG o2B01 does not really look like my part. The item in the picture appears a thin flange, but mine is two flanges with a round casting connecting the flanges. It bolts to each component with four fasteners. Since my flange is only cracked, and other than leaking; welding my old flange may be required if part is not available, or fabricate.
Worst case, I will have the part fabricated.
The entire transfer/emergency brake kit is DAPN2N69DA
Wayne
Wayne
