Ford 4000 Hydraulics
ford7600
Post by ford7600 »
Does anyone on here known the answer to this :- I have a 1968 Ford 4000 that will lift it hydraulic arms but say you attach a small Vicon Vari spreader ( which is a light load) refuses to lift at all. What is the problem and how do I fix it !!!
ford7600
Re: Ford 4000 Hydraulics
Post by ford7600 »
In the end I found the Problem it was a seized spool in the flow control valve
Glad you solved it. Congrats
