Ford 6700 Dual Power Transmission
Posted: Thu Mar 04, 2021 6:29 pm
by Marius47
The dual power gearbox is limited to 25 km as I can increase it to 30 km ?
Re: Ford 6700 Dual Power Transmission
Posted: Mon Mar 08, 2021 9:48 am
by Old Hywel
Wide 38” tyres would give a larger circumference, and a higher road speed.
Posted: Fri Mar 19, 2021 12:19 pm
by Marius47
Yes, but the ones made for Europe are limited to 25 in the rear differential from what I heard.
That's why if he could change that limit to the original 30 km.
https://ibb.co/XLs58yJ
Posted: Fri Mar 19, 2021 12:43 pm
by Emiel
Rev it up to 2400. And enjoy the time in the tractor seat instead of driving faster and having less time to enjoy.
Posted: Thu Sep 30, 2021 8:48 am
by shepp
There were these differential differences through the whole range from the 6X 1000 series onwards, tractors built at Basildon for the UK market had a diff that gave higher road speeds whereas any Basildon built tractors that went to Europe had the diffs that restricted speeds to 25 kph. You will be able to fit a UK diff in your tractor to increase road speeds.
A friend has done a great conversion of a Belgium built pre-force 5000 by fitting the UK diff and a 7840 engine modified with a Bosch inline pump and turbos, large diameter rear tyres - see it go on road runs!
