I guess the question that should be asked,"Did they ever make a footrest for the left/clutch side of the Dexta/Super Dexta?" and if they were, where can you get them?Personally I've never seen one. Cheers TSG.
If you remove a right hand one and turn it over there is the same chequered patern so I assume they can be fitted to both sides. I intend fitting one to each side of mine.
1964 New Performance Super Dexta - Shiney but still needs work!
About an hour later I was looking at the footrest on my Super Dexta that I realised that its symmetrical.So if you get another footrest like you have by the brake pedals you can use it upsidedown on the clutch pedal side.But then you realise that will this make it harder to get on and off the tractor? and if you do use this footrest, will the clutch pedal will dig into the back of your leg?Maybe its better to have no footrest? TSG.
