Wanted - Dexta front axle support & bracket assembly
Posted: Thu Aug 13, 2009 8:50 am
by Dextrous
Mine has seen some major trauma or modification in the past and has had some very dodgy welding done to it.
It is the large steel bracket that bolts to the front of the engine below the fan, the front axle is connected to it via the large bush and pin and the radiator sits on it.
Part number is 957E-3048.
Andy
Posted: Thu Aug 13, 2009 2:41 pm
by Bensdexta
I got one from Ron Greet. Not expensive.
Ben
Posted: Fri Aug 14, 2009 8:24 am
by Dextrous
That was my next port of call - I hope you didn't take his last one.
Posted: Fri Aug 14, 2009 9:20 am
by Bensdexta
Dextrous wrote:That was my next port of call - I hope you didn't take his last one.
I believe Henman are breaking a Dexta,
All the best,
Ben
Posted: Mon Aug 24, 2009 7:57 pm
by roromac
I have one in good condition without inboard light brackets. FOC if you can use it.
Rob
Posted: Fri Aug 28, 2009 12:17 pm
by Dextrous
That sounds great Rob. I'll email you and sort out a courier to pick it up.
I've got a a Dexta instrument panel without the seperate ignition hole going FOC if any one is interested.
Also I had to buy a pack of 25 grommets just to get the big one that protects the hole that the tachometer cable goes through from the instrument panel. Fits really well. Again FOC if anyone wants one.
Andy
Free Grommet!
Posted: Tue Sep 01, 2009 11:56 pm
by Bensdexta
Andy,
Did you get my pm ref the free grommet?
All the best,
Ben
Posted: Wed Sep 02, 2009 12:41 am
by Dextrous
Just - I've been under orders to do some decoratiing.
Andy
