Wanted - shims for dexta steering box top nut
Posted: Tue Sep 08, 2009 8:12 am
by Dextrous
I may have to make some, who saves them when they take them out?! However if you have any knocking around, I'll swap for some from the lower part of the box :wink:
Initial measurement after putting in a new top nut and bearings indicates about 0.1" are required, although I need to take a closer look.
Andy
Posted: Tue Sep 08, 2009 1:00 pm
by Tubal Cain
It is a spacer that you need not a shim! Do you need it to fit between the bearing race and the cover or between the cover and the column? You can always try using some thick jointing if it is the latter.
Gerald
Posted: Tue Sep 08, 2009 1:24 pm
by Dextrous
Hi Gerald
It's between the cover and the column. According to the workshop manual there are 0.004in shims and a .007 gasket. The top is tightened down to remove play then the gap measured and appropriate shims fitted.
I have only tightened the cover a little over hand tight, the 0.1" will go down, not sure how much until I'm allowed another tractor tinkering window - probably Friday.
I do have a selection of gasket material of various thicknesses so this may suffice, it will be easier than making it in steel sheet.
Maybe we need to start a shim bank to put all the shims you take out when adjusting for wear......
Andy
Posted: Tue Sep 08, 2009 1:57 pm
by Bensdexta
Your local ag mech may have some. I've just had my steering box done.
All the best,
Ben
Posted: Tue Sep 08, 2009 2:13 pm
by Dextrous
We do have a long established ag mechanic - I'll go round. Only trouble is he can talk for England - it may take me 2 or 3 hours to establish whether he has some after all the various stories come out!
Posted: Tue Sep 08, 2009 2:45 pm
by Bensdexta
Dextrous wrote:We do have a long established ag mechanic - I'll go round. Only trouble is he can talk for England - it may take me 2 or 3 hours to establish whether he has some after all the various stories come out!
Go just before 'home time' :wink:
Posted: Sat Sep 12, 2009 11:10 pm
by Dextrous
I went round to see our local Ag mechanic, fortunately he was busy so I got a terse answer! He had no shims, but a shiny new office and apprentice - I think he has set his apprentice on tidying up and has probably binned all those not often used but very useful bits. :(
