Over the weekend I was rebuilding the gearbox (Bearings & Seals)
I was installing the pins that retain the transmission brake plates, when i was torqueing up the short pin i broke the pin. When looking at the pin it was cracked half way through.
I'm hoping someone has a gearbox that they are parting out, so i can purchase one, or steer me in the right direction where i can obtain one.
The part number is - N-7706-E Pin (Transmission Brake Plate) - Short.
Thanks. Willsy/Aus
E 27 N Gearbox Part required-Aus
