Hi has anyone got some pwer major handbrake discs or know where i can buy some from?
Power Major Handbrake discs
Re: Power Major Handbrake discs
I don't know any one who has new hanbrake disks for a power major listed, but there may be a chance that E27N disks might fit. Old 20 http://old20tractorparts.com sell new E27N ones. If you had the Power Major part numbers you could check. E27N part numbers are N-7704-B and N-7705-B. My parts book is for E27N only so I have no way to check if the later tractors carried over the same parts. I know the disks carried over from the model N so there is a chance they may fit. I would certainly send Old 20 an email to ask if they knew.
Regards, Frank.
Regards, Frank.
Just a quick update. I went to the main web site and looked up the on line parts list. http://www.fordsontractorpages.nl/manua ... s_list.htm
Pages 121 to 140 have the gearbox part numbers. I went through the list and the handbrake disks have the same part numbers as the E27N ones. You might want to double check the parts list to make sure that it refers to your transmission, but it looks like the E27N ones carried over.
Regards, Frank.
Regards, Frank.
Thanks for that very interesting, will do my homework and let you know.
Also just found out that QTP list them new,part numbers 41455 Handbrake ware plate and 41454 Handbrake disc.
Who's QTPoldblue wrote:Thanks for that very interesting, will do my homework and let you know.
Regards Kenneth
Fordson for life...
I think QTP is these guys http://www.qtponline.com/
Frank your spot on the discs are the same as a E27N.
Thanks for that
Thanks for that
